Render Alpha. Need preset for Lighting and Material so I can render export Alpha
Need preset for Lighting and Material so as to export an Alpha render.
Like the image above.
There is no rendering or materials used to create Alpha’s in ZBrush. In the Alpha palette, you would simply use “From Mesh” or “GrabDoc” buttons to create the alpha, then Export from the Alpha palette. “From Mesh” would be the quickest and easiest way.
2019-07-16%2009_03_00
Wow thanks for that, soo simple!
What about color value, is there a GrabDoc button to capture exact same size color image to match the alpha produced by the GrabDoc function.
