Removes errors related to brushes:
- during mask mode change
- during selection mode change
- during smoothing change
- snake hook error, that it works better with sculptris pro
- morph error, that you need to make morph target.
Installation: place in the root folder of the program C:\Program Files\Maxon ZBrush 20XX\ZStartup\Macros
A Start button will appear in the Macro panel. It can be moved to the interface or set as a hotkey.
You need to press it at the beginning of each working session, the script selects all problematic brushes, presses the “Skip” button, and then selects back the standard smoothing, masks and the move brush.
Downoload https://artstn.co/m/l9br8
I tried for a long time to make this script a startup script for zbrush so that it doesn’t have to be pressed, but it didn’t work for some brushes.
I left warnings for merging, deleting subtools, but removed for brushes. It’s very annoying that zbrush after 7 years of working in it continues to tell me every day “Snake Hook works better with Sculptris Pro”
