Hello! I recently downloaded Marcus Civis’ script for removing the pop ups from the mask, selection and smooth brush and added in some code to also remove the sculptris pop up from the snakehook brush.
I was trying to do the same for the pop up that appears when coming out of edit mode however it seems like the prompt doesnt trigger in the same way it does with brushes?
I tried various types of code like copying Marcus’ original template or writing something more direct. Even if I use the recording feature and add in a line to press the prompt (example below), the prompt will still appear even if the script is loaded after opening a file with a subtool in it.
[IUnPress,Transform: Edit]
[IKeyPress,‘3’]
[IPress,Transform: Edit]
