Is it possible to remove any any all references to images be they (background, front/back, top/bottom, left/right) from a ZBrush project with Zscripting?
Which reference images are you talking about? (Image Plane, Grids…)
All of them! Planes, background images, textures, lightbox and others I probably don’t know about
The simplest way to get rid of all the reference images set up is to use the Tool>Copy Tool button to copy the model and then paste it into a clean project. If the project has more than one model then you’d have to repeat the procedure for each one.
But what that won’t do is get rid of any images that have been loaded into the Texture palette. They persist throughout a ZBrush session. They aren’t saved with the project though, so if that is your main concern there is no need to worry.
This is so dumb as a work flow. Why can’t you either turn off the image plane or image? Why are so many steps required for a simple task?
