Whenever I use a brush - it doesn’t mater which one - a square border is visible around the affected area, which disappears as soon as I orbit the camera. Please see attached movie.
Hello @Velvia33,
There are a few different scenarios I’m aware of with which this can happen under normal conditions.
This sort of effect is known to happen to some degree when using Dynamic Subdivision in conjunction with Sculptris Pro mode. There is nothing to be done about this.
There is a known issue in the currently released version of the program where you will see this effect if you have the “Distance” slider in the Lighting Palette set to a value less than 100.
I have also seen this as a mild file corruption issue. In this case, loading the tools into a new project by using the Tool> " Load Tools from Project" function corrected the issue.
If none of the above is applicable, you will need to contact Pixologic Support and Start a Conversation there.
Thank you!
