Rebuild custom UI after upgrading to 2020?
Is the 2020 upgrade one that requires rebuilding my custom UI from scratch like for the 2018 version ? I am using the same custom UI since 2 years now , seemingly without problem.
You shouldn’t have to. My UI ported cleanly enough, and I’ve seen others do the same.
I’ve recycled UIs plenty of times without issue. But I’ve also seen lots of problems reported with forward ported UIs over the years. As far as I know it still isn’t recommended, so proceed at your own risk. It can result in odd behavior.
Thanks for the feedback. I guess it wouldn’t hurt to rebuild it this time. To someone without any programming knowledge it seems odd, the UI buttons must be more than just "links " to the algorithms they are associated with.
Things can change in between program versions. I’ve seen issues ranging from weird visual glitches to outright crashing reported with recycled UIs.
However, you may not experience any issues at all, so roll the dice I say. If there’s an issue, you’ll know what to suspect first.
Interesting. Thanks again Spyndel !
