here are some really annoying bugs i am experiencing
windows 7 64bit
those i experienced in versions lower than 4 also happened in windows xp 32bit, since i am now working on a totally different mashine than back in the 3.x versions i assume hardware is not the problem as aint OS bits or OS
undo hotkey:
is stops working from time to time without reason it seems, i even added those undo hotkey lines to the startuphotkey.txt but it didnt help at all
ZBrush versions: all (since 3.1 tested)
annoyance factor: 10/10
current workaround: restart, use ctrl+y instead
explanation: ZBrush seems to switch over to the qwertY keyboard setting, i usually use qwertZ tho and hence it seems as if ctrl+z would stop working, indeed it does not, it only becomes ctrl+y on german and french keyboards…
brush Z intensity:
soetimes after switching back to clay buildup (i assume its similiar with other brushes) its adding/substracting alot more Z value than it should and i have to turn down Z to 1 or 2, then seemingly without reason after a few strokes or after switching brush it goes back to normal (could be tablet related but it happens too if i use the mouse and did not happen in versions 3.x afaik hence eliminates the tablet id say)
ZBrush versions: 4R2
current workaround: change brush, paint, swap back to the brush
Z add/sub swap:
its rare but sometimes Z swaps add with sub, meaning it paints positive when im in Zsub mode and vice versa
annoyance factor: 5/10
workaround: restart or just live with it
negative RGB during Zsub:
sometimes using Zsub while RGB is active it paints a negative rgb value meaning it paints black instead of white, could be intentionally as ive seen it happen in one of the tutorial videos too, think it was that how to sculpt lips video by Ryan Kingslien
annoyance factor: i assume 10/10 if you try to polypaint while sculpting, didnt have that problem yet tho
workaround: turn off rgb
dynamesh not doing anything:
right now i have a tool at 560k polies for which id like to increase the resolution but all i can do is lower it, increasing it does not do anything at all, i had however another tool with more than 2mil polies yet and dynamesh active and it did not stop working
workaround: none, even reloading the tool, exporting and reimporting, restarting Zbrush does not help, i could use subDs now but then i couldnt activate dynamesh again or loose all the detail
explanation: dynamesh is hardcoded to only support 1024 polies on each of the three axis, theoretically that could mean around 6mil polies for a cube, much less for elongated shapes tho
mem settings getting reset
happened before i used that UI hotfix available in the ZBrush 4R2 faq, saving the config didnt help and it always reset itself to 256mb upon restart, the ui fix however seems to have helped even tho it was actually for somin else lol
annoyance factor: very high if you didnt realize it did reset like me and wondered why a 2mil poly tool moved choppingly like a 20mil poly tool
workaround: get the hotfix from the Zbrush 4R2 FAQ (at the very bottom)
