I need a backup solution, I’ll be using the following motherboard and disks.
http://www.newegg.com/Product/Product.asp?Item=N82E16813131025
http://www.newegg.com/Product/Product.asp?Item=N82E16822148140
In Raid 1 w/2 Disks. It’s easy to fix. No performance boost. Perfectly content with this as a pure backup solution.
In Raid 5 w/3 Disks. It’s a little more tricky but I’d be perfectly fine backing up my stuff and starting over, once the disk is replaced, if the Raid cannot be rebuilt after failure. That is, if there is a good performance incentive for both the added trickiness as well as the cost of a 3rd HDD ($90).
In Raid 10 w/4 Disks. It seems simple enough but now there’s two extra HDD’s to buy. Again here the only reason I’d do this is for nice a performance boost over Raid 5.
My uses will primarily be 3D Modeling/Animation, Photoshop and some casual gaming. So, Performance boost wise, what am I looking at between these three scenarios. Thank you very much in advance -Derek
