Radial symmetry with the Knife Brush Circle?
A noob question, Vers. 2022.0.1 is there a way to use radial symmetry with the KnifeBrush Circle? Mirror symmetry? Is there a way to create a perfect Circle with it?
Please Santa, tell me I can!
Many thanks.
Hello @Voxel ,
The Knife brushes do not support Radial Symmetry.
The Knife Brushes do support Mirror symmetry in a limited fashion. Symmetry will disable itself if you attempt to cross the center line with the Knife cuts.
Select the KnifeCircle brush and go to Stroke> Modifiers and enable “Square” and “Center” while the Knife brush is active (you will need to hold down Ctrl+ Shift).
The answer to many of these questions can be found in the documentation:
http://docs.pixologic.com/user-guide/3d-modeling/hard-surface/clip-brushes/knife-brushes/
Thank you!
Thank you.
