So i am new to zbrush and to sculpting world in general, and i have a problem with radial symmetry, where i want it to go on the eye, it just goes like somewhere else
It’s because the subtool is not centered in world space. A subtool has to be in world center in order to use symmetry. ZBrush has 2 buttons in the Transform palette called “S.Pivot” (Set Pivot Point) and “C.Pivot” (Clear Pivot Point). S.Pivot will temporarily move the subtool to world center so you can sculpt on it using symmetry and, when you are done, you can click C.Pivot to move the subtool back to its original position. If both spheres are the same subtool, symmetry won’t work. In that case, you would sculpt on one eyeball as it’s own subtool, then you would duplicate it to get the second eyeball.
