Hi:
As far as I know, the curve in the sub tool is stored in the memory,Can Zscript copy the curve data in the current memory to other sub tools? And use [Curve to UI] script to get that curve。
Unfortunately you can’t grab the data for an existing curve using zscript. The only way to do this would be if you had created the curve using zscript.
HTH,
Marcus
Thank you Marcus for your reply.
