How is Quick Sketch Mode activated, what are the steps?
Thank you
…so the search engine is that exact?
“QuickSketch”
but not “Quick Sketch”
Search Result:
http://www.zbrushcentral.com/search.php?searchid=3406105
http://www.pixologic.com/docs/index.php/Special:Search?search=Quick+Sketch&go=Go
<H1 class=firstHeading>Search results
From ZBrush Info
For query “Quick Sketch”
Jump to: navigation, search
For more information about searching ZBrush Info, see Searching ZBrush Info.
Showing below 2 results starting with #1.
View (previous 100) (next 100) (20 | 50 | 100 | 250 | 500). No page title matches
Page text matches
- Zac Berry (1920 bytes) 10: ==Quick Sketch==
- Eric Keller (1631 bytes) 6: 1. Enter Quick Sketch Mode.
14: …mask and hiding the unmasked areas, I was able to quickly create a layer for the glowing magma.
</H1>
" To get started, all you need to do is click the QuickSketch button. "
I’m smart enough to figure out how to activate a button, but WHERE IS IT supposed to be located? :o
Never mind It looks like ZBrush 3.5r3 did not launch.
see it clear as day.:rolleyes:
Online documentation. http://www.pixologic.com/docs/index.php/Main_Page
There youll find explanations for all the functions of Zbrush. QuickSketch is a new feature so there hasn
t been written a lot here in the forums. As a result you cant find much about it with the ZBC search feature at that moment. ( At least that
s what I think why you haven`t been able to find something.)
Theres also a detailed what
s-new-documentation in your Pixologic Zbrush 3.5R3 folder (PDF file).
PS: The button is on the left side.
Quote “To launch Quick Sketch, click on the Quick Sketch button located on the right of the Projection Master button, under the Draw / Edit Palettes, or in the Zplugin >> QuickSketch
menu”
