Hi all,
After years of reading and learning a lot from this forum I make my first post with a little tool.
A few months ago I got the idea of sending a model composed of multiple objects from Maya to ZBrush without the hassle of export and name each object and in ZBrush import one at a time and then add them as subtools, again one at a time.
It’s not that it takes a long time but all the export every object seperated and naming files then import one at a time as subtools… naaaaaaa… that’s why there is scripting, to make the machine work for us
So for that I created a Mel script that you can download from here mgExpObjsGrpToFolder.
In a base level it’s just a handy *.obj exporter since it exports every object with the proper name in a selection Set and gives the name of the set to the folder where the *.objs will end up. Now the new thing is that it creates a little macro script to create a tool in ZBrush that contains all the objects as subtools with proper names and the same order. Unfortunately and since this is a first release it has some bugs, it only runs on windows and the interface in ZBrush isn’t very elegant.
Planning to convert it to python in a next release.
Quick guide:
In Maya
Install
- Make sure you have the objExport plug-in loaded.
- Source the script “mgExpObjsGrpToFolder.mel” or make sure it’s installed properly.
- In Maya select your objects by the order you want say first head then body then legs, etc, etc ( this matters because in ZBrush the subtools will appear in this order)
- Now, create a selection Set and name it correctly(this will be the name of the folder where the *.objs will end up)
- Finally select the selection set you want to export and run mgExpObjsGrpToFolder;
- A browse window will appear, select where the folder containing the *.objs should be created(don’t select any path with spaces, its not supported at the moment)
- After you select the folder and clicked “ok” a folder with the same name as the Set will be created and the objects will be exported.
- Go to the Zscript>Load button (or press CTRL+SHIFT+L)
- From the browse window select the loadmacro.txt file that was created with the *.objs
- A new button in the Tool menu will appear saying “import”+ the name of the Set you exported from Maya
- Click on this button to create the tool
- After this the tool is created and selected, you just need to draw it on the canvas an enter the edit mode
Cheers,
MacGio
PS: I know SubTool Master allows to import multiple *.objs as subtools but anyway, hope this is useful for anyone.
