help! does anyone english speaking can tell me what means in cm, or inch, the following: “6 picas by 6 picas”?.. thank you!
I think 6x6 picas is 1x1" inche, When you key in 6x6 picas into the image size in photoshop, it converts to 1x1".
Don’t know what is it for and you can set your ruler to picas to see the value and vise versa.
thank you! that solve my problem! filip, try the carrara french forum, it is active, and you can speak english!..
Picasso
So 2.54 cm * 2.54 cm = 6 picas * 6 picas = 1 inch * 1 inch = 72 points * 72 points
If I had understand
It’s a stamp marcel
Thx Fouad!
Pilou
Ps Filip
Marcel :rolleyes: has forgotten the Adress of Carrara Forum !
en imprimerie 1 Picas = 12 points
Be careful when you read the color convertions of CMYK v RGB on the link to the Digital Expert.
Some of the articles were removed and because there are significant reconigtions to the ICC profile.
It solves problems not the cause of the problem. If there is only one standard then we will be looking at the same picture, unfortunately all manufacturer seems to create their own standard.
