Hi, I’m trying to record a script (but I’m willing to write it) that will rotate an object and all it’s subtools 18 degrees to the left, render the image and save it. It will repeat the process 19 times to complete a rotation. Now comes the tricky part. I want to drop it 9 degrees on the y axis and go around again. You know what i’m gonna say next. GYMBAL LOCK. Is there a way to translate this so i can type in precise incriments?
This is so I can produce 400 or so images of an object to be used with a macromedia flash utility that allows you to click and drag to “rotate” an object.
I’m trying to do 19 frames around 19 azimuthal levels.
Obviously I can’t use a Zscript to record a Zscript, but if I could get help on how to write it, I would appreciate it.
