QUESTION☼
When I record my brush strokes in ZB 3.1 using the z script→record and then load the script back in after doing everything I wanted recorded (a few brush stokes in variouse angle views) I play it back and it works perfectly. Well when i try doing the exact same thing in 3.5 it only records the brush strokes and none of the view port stuff, so the brush strokes end up being placed in the wrong spot and it goes all wacko? I looked at the scripts from each version on separate computers and they looked identical to me?(i read the zscript info and comand list havent tried to create anything so dont know much on it) I have looked through the forums but i only found possible work a-rounds that i didn’t completely get, didn’t even find anyone that had encountered the problem? any suggestions? should i post the script recordings or any thing?
Any help is apreciated !!! I was so happy when this worked in 3.1 an dit would make my work so much faster if i could getit to go rigght in 3.5.
