I recently started learning Zbrush.
In one of the tutorial videos, I learned that you could move multiple subtools in space by the same distance by using “ReplayLast” function (shortcut - 1).
When I tried it however the function would often not work. It would rotate the document or do nothing most of the time.
I made sure I did not accidentally sculpt or touch anything in between while switching subtools, but still no good.
I am using Zbrush 2018 and use Gizmo to move and rotate, while in tutorial video it’s older version.
