do i have to restart zbrush everytime i projected a texture? coz once i project a texture and try to load a new texture it loads same texture automatically
If you have a texture selected then the plugin will use that. To load a texture from disc, simply make sure there is no texture selected.
i mean everytime i projected an image texture and wish to use another texture it load the same image, i think im doing it wrong. do i have to make new texture after projection to make another?
Are you using Projection Master? If you are, drop your model in PM then either:
a) Select the image you want to use in the Texture palette and then press the Image Plane button. (Note that you might need to select the Simple Brush in the Tool palette before you can select a texture.)
OR
b) Make sure no texture is selected and press the Image Plane button to select the texture from disc.
Thanks Marcus
