Is there a way to erase only the last mask applied after you edit the mesh? Example: I mask half of model, used move brush, after, mask the model again in another part, used move brush again, but now, I want to wipe the last mask only with one click. Have a script or another able to do that? Thanks.
Do each mask on a separate layer, then sculpt on another layer and delete the mask layer you no longer need masked.
Thanks!
