Hello ,I am a little confused about the [Currve to UI] script, Every time I run this command. The Curve Will be generated in system memory.But the Next time The curve to UI script will keep the Last point to generated the new curve . So how to clean the last time script curve point in the memory ? Is there any solution to fix this problem ? Hope someone can understand and give some help. Thank you 。
Welcome to ZBC!
Just use [CurvesDelete] when you want a clean start for your next curve.
-Marcus
Thank you Marcus, I will Try !
