I’m using ShellExecute to open Character Creator.exe, which is under Program File. I tried opening other files which their path doesn’t contain space will work as expected.
You need to put the path in quotes: "C:\Program Files\Character Creator.exe"
Sometimes you might need to use the [StrMerge] command, in which case it can simplify things to use the ascii value for the double quotes:
[VarSet,pathToExeFile,[StrMerge,[StFromAsc,34],"C:\Program Files\Character Creator.exe",[StrFromAsc,34]]]
Thank you very much. I never thought that I can merge string with StrFromAsc.
