Is there any script floating around somewhere that makes context-based decisions on Polygroups in ZBrush? Something that would do the Auto Groups function normally, and if the user created a mask, it would instead do Group Masked. Doesn’t need to do exactly this i suppose, if it’s similar I could Frankenstein it myself.
Here’s a script that will do what you want, and that will perhaps serve as a model for other stuff. The main problem here is checking if there’s a mask. The script has to test this by seeing if the unmasked part of the mesh can be hidden - not ideal but the best I could think of.
[RoutineDef,CheckIsMasked,
[IFreeze,
[If,[IExists,Tool:Visibility:HidePt],
[IPress,Tool:Visibility:HidePt]
[If,[IsEnabled,"Tool:Visibility:Grow"],
[VarSet,isMasked,1]
[VarSet,isMasked,0]
[IPress,Edit:Tool:Undo]
,isMasked]
[IButton,"Group It","Create a new Polygroup using AutoGroups or Mask",
[VarSet,isMask,0]
//check we can actually use Group Masked (it's a polymesh or zsphere in preview mode)
[If,[IExists,Tool:Masking:Group Masked]&&[IsEnabled,Tool:Masking:Group Masked],
[RoutineCall,CheckIsMasked,isMask]
[If,isMask,//it's masked so use Group Masked
[IPress,Tool:Masking:Group Masked]
,//else no mask - AutoGroup
[IPress,Tool:Polygroups:Auto Groups]
HTH,
Marcus
Hi Marcus, thank you for your sharing of this. However, if I save this to my Macros folder and restart ZBrush (2021), I don’t see this script appearing amongst my Macros. Does this not mean the script has errors and is not being read on startup properly?
EDIT: Nevermind, I was being a donkey. Thank you again Marcus, this is exactly what I was asking for
You are amazing.
Hi Justo,
I’m glad you got it working and it’s what you want!
For the benefit of anyone else wondering about macros, they use ??? instead of the button name, so this line in my code:
for a macro becomes:
[IButton,???,"Create a new Polygroup using AutoGroups or Mask",
-Marcus
