When I record macro, It comes back a bit lack infomation.
If It can, I would like to change ZModeler’s “Polygon Action, Target, Modifier” by Zscript.
Hi @star0worshipper ,
no you can’t the zmodeler is not exposed with ZScript, but you can save the brush with different setup and load them via scripting.
Hope it helps:,
Nicolas
Thank you for answering!
If I use that method, could I purge the selected brush from brush menu?(not reset brush menu entire)
In ZBrush, the once loaded brush is still there in that session.
Maybe, this method need a lot of custom zmodelers need.
So, I may need to purge them for stable perfomance. (I hear ZBrush will unstable when load the brushes too much )
no you can’t to unload a brush until you restart ZBrush, a zmodeler brush is quite a low sized file, it doesn’t contain alpha map etc… so don’t worry about performance. And additionally via a plugin you would load the brush at runtime, not at the ZBrush startup.
Hope it helps,
Nicolas
