Question about Posotion in keyshot
Hi All Dears
Kindly i have problem when i render my work from ZBrush to Keyshot by using (Bride) i using ZBrush 4R7 P3 and contain bride to keyshot the problem is :
the location my work in keyshot don’t like in ZBrush its be different position? what is the solve for this problem plz??
thanks for your time
Both ZBrush and KeyShot default new objects to the center of their world.
I think this is a limitation in a way, but that seems to be how it is.
However, I think it should be possible to make an object (subtool) that surrounds the objects you are working on and you can adjust that to cause KeyShot to have placement information in relation to what you are working on and the surrounding object. I dont know if that would help you or not, but its worth a try.
If it does work, all you have to do is delete the surrounding object when you are done with it.
Thanks dear for help me
