question about max plugins
does anybody out there now if there is a obj to max plugin That will work with version 5.1… if so will you please post it thanks for your help…
2 Obj Plugins here
Freeware and some old but who knows :slight_smile:
Explore that Maybe some possibilities !
Pilou
Oop, Pilou put up the ones I have.
This site also lists plugins if you need others, though they have no different max2obj/obj2max porters. I haven’t seen any at all for 5.1; do the current ones not work at all with 5.1?
BTW, I PMed a link for a UVW mapping tut for Max 5. If you didn’t get it, here it is again Max 5 UVW tut
Hi Bonecradle
Your Max’s Tut is very detailed !
You are a max Guru :slight_smile: I see also that max is always a gas refinery :smiley:
Do you know the Max tuts of this guy?
in french + english :slight_smile:
Pilou
thanks so much frency,… this site is a winner. http://www.3d-station.com/ressource/impexp.php
thanks for you tut bonecradle. i printed it out and ive aready followed through with it… and yes the objtomax plugin doesnt work with version 5, the only one that i can use is the one posted here given by frenchy.
EDIT: :large_orange_diamond: :large_orange_diamond: :large_orange_diamond: you can find the import obj plugin that works with version 5 by clicking the link above.
the plugin is called alias wavefront importer v 4.2. note: its a french site but it looks like a really cool site for max users. thanks frenchy i hope this is what you wanted me to do.
Hi Dr
Delight that help you, but I think that you must take the definitiv name or the direct link of the Plugin who work fine for the other Zbrushers(in particular Aurick :slight_smile:
(I have given a lot so what is the good ? :smiley:
Pilou
Ps Dr JJ has token the name in his update Post :see upside :slight_smile: Thx for him :slight_smile:
I’m glad the tut is useful, though I should make clear that I didn’t write it.
Apologies if my message gave that inference; it certainly wasn’t my intention to do so.
Hi Bonecradle
You will make the next for Zbrush :wink:
Pilou
