I have a weird suspicion that I’ve overlooked something. Is there a way to show a heads up display text in the corner of the zbrush interface somewhere that informs me when a script is being applied?(not a text that pops up that you have to click on) For example, if I make a script that toggles something on and off, can I have a heads up display that shows me the status of the toggle for a second or two? thanks!
You can use the NoteBar - the strip below the palette titles. This is used by (for example) Transpose for position info etc. and when render or other operational progress is shown:
[NoteBar,The Message that will be shown (use empty string to clear current note),Optional progress-bar value (0=Min, 1=Max)]
//Displays a note in progress bar.
