<center><font size=3>Introducing <font size=5><font color=#FFA000>Quad</font>Quick</font> – multiple view port modeling for ZBrush</font>
[img]http://www2.zbrushcentral.com/zbc_uploads/user_image-1033332998qei.jpg[/img] </center>
There have been numerous requests over the last year or so for multiple view port modeling in ZBrush. Now, with <font color=#FFA000>Quad</font>Quick, you can have it! This powerful utility allows you to display your model from four different views while you work:
:small_blue_diamond: Isometric
:small_blue_diamond: Top
:small_blue_diamond: Right
:small_blue_diamond: Front
All four views can be displayed at the same time:
[img]http://www2.zbrushcentral.com/zbc_uploads/user_image-1033333529umv.jpg[/img]
Or you can switch to enlarge a single view port:
[img]http://www2.zbrushcentral.com/zbc_uploads/user_image-1033333557wjq.jpg[/img]
Here are a few of the features:
:small_orange_diamond:Customizeable backgrounds allow import of a reference picture for use while modeling. Each quadrant can be assigned its own background.
:small_orange_diamond:Transform mode is remembered when you switch between views. For example, if you have the Rotate Gyro active when you switch views, it will still be active in the new view. This holds true for all gyros, Edit>Draw mode and Edit>Move mode.
:small_orange_diamond:Refresh button refreshes the model in all four quadrants or returns you to Quad view from Single view.
:small_orange_diamond:When using the Refresh button to switch out of Single view, the active view is remembered when you switch back to Quad view. So if you're working in a Single view of the Front and switch back to Quad view, the Front quadrant will automatically be active. And it will still remember your Transform mode!
:small_orange_diamond:Built-in tutorial explains the basics for those who wish to dive right in.
:small_orange_diamond:Comprehensive PDF User's Guide explains the script at length for those who want more details or would like to have something to refer to while they work.
:small_orange_diamond:It's <b>FREE!</b> :)
<hr width=50% align=center>
<center>Discover the joys of Quad View modeling. Download <font size=3><font color=#FFA000>Quad</font>Quick</font> today!
(It should be noted that this script will not work for users of the ZBrush demo.)
:small_blue_diamond: :large_orange_diamond: :red_circle: <b>[Click HERE to download (713 KB)](http://www2.zbrushcentral.com/counters/increment-zscripts.cgi/z00QuadQuick.zip?3utilities/z00QuadQuick.zip)</b> :red_circle: :large_orange_diamond: :small_blue_diamond:
In order to avoid confusion or problems, it is strongly recommended that you either run the tutorial or read the User’s Guide before you start to use the script.</center>
Happy modeling!
