Hi
I want to dig a bit deeper into the layer system of zbrush, fairly limited but here goes:
I naturally want to get the names/values etc. But the big thing is to get the value of how many active layers there are. I see that the window ID has a set number, and if you scroll down in the layer window that number is the first layer in the “active area”
So Layer 0 would be 327, layer 1 would be 328 (window ID). If you scroll down if you have many layers, the layer that is at the top of the window for example layer 8 would also be 328.
Is there a better way to track this, create a list etc.
Thanks in advance.
