Is it normal that when I set Projection Strength high, the program freezes? I usually do not complain about my computer, but in this case I want to know why it consumes so much resources?
For example, here is the density of the grid of the ball and the ornament that I am trying to put on:
Hello @Araders ,
If you are referring to the Brush> Modifiers> Projection Strength feature for use with IM brushes, then yes this is normal. This feature is doing a lot of things simultaneously, and the performance burden increases drastically with higher point counts. Using IMs with points counts that are too high for the feature may result in performance related issues.
I would suggest dropping the resolution of that mesh by at least half to work with that feature.
For higher resolution meshes, ZProject, Matchmaker, Dynamics, Subtool Projection, and Alpha Displacement are possible alternatives.
