Hello, I can’t seem to get my undo history from projects to save/load. Can you help? I have all the options that are recommended to get it to work selected.
Also I’ve been having the problem of when I mouse over a menu item at the top of the screen it never seems to select the correct thing. I have to start at the left side of the menu and then slowly mouse over each menu item in order to properly select the ones on the right side. This doesn’t matter if I have a custom UI or default.
Thanks
