Hi guys, I’m trying to project polypaint to a layer.
If I project, I get a really faint projection, even with RGB set to 100% and even if I paint out the layer with a solid color first.
I know the workflow for doing this with a sculpt - I can import a mesh (with identical verts) as a morphtarget and then paint out the morph using the morph brush with the 3D Layer recording
Does anyone know if there is an equivalent workflow for getting existing polypaint data onto a layer?
Thanks in advance and sorry if this has already been answered
You’ve already discovered the workaround that I would recommend.
