as Pilou said it would take 5 minutes to do a moebius-strip i gave it a try (for much longer time :D):
i doubt thats close to a moebius-strip, but it was big fun, anyway. like monkeyfarm i now doubt theres a way to do it properly within z, but would love to be proven wrong
basically i started off with an antique pre-spiral and helix-tool-days method of rotating a 3d-ring (with adjusted radius) by x-90 and applying negative twists a few times, smoothing in between. with mask all + col + sel32 it was easy to move half of the ring to where i wrongly thought it appropriate. coloring was done via select>mask all> row, then inverted. it is also a first attempt at using boozyās cyclorama-tip
the other one is a selfportrait on the moebius-trip
any comments would be mucho appreciated, but even more so your own attempts at moebius-ing and findings
- juandel
