It doesn’t project any details but makes artifacts. I tried everything but to no avail
Edit: dunno why but now it works with no problems??
Hello @Allex ,
You would need to document the problem in greater detail with images. The most common issues with projection is having too low of a value for the .dist slider, which will limit how far the surface can project outward. This might result in spiky “artifacts”.
Please also be aware that marked history states can influence projection results:
http://docs.pixologic.com/user-guide/3d-modeling/sculpting/project-undohistory/
In the future, please provide an uncropped image of the entire interface so we can get a better idea of the problem. Any technical issues with ZBrush should be directed to Support.
Thank you!
