Problems with mirrored Fiber mesh
Hi
I have recently stared using fiber mesh a lot more.
The problem I am having is when you mirror a chunk of fibermesh you can no longer use the smooth brush on it.
All other brushes work but not smooth.
In fact if you turn off fast preview, the smooth brush actually seems to delete the geometry
Am I just wrong? Or is there a work around for this?
Thanks
Simon
With Smooth brush selected, go to “Brush > Smooth Brush Modifiers” and lower the “Minimum Connected Points To Smooth” slider to 2. If you still need more, lower it to 1. Default value is 3.
Thanks for the reply, unfortunately that doesn’t seem to work.
I ‘think’ something must happen to a fibermesh when it is mirrored that breaks it
What is strange though is that if you mirror the same mesh back again it works fine, same as the original does.
thanks
