Problems navigating with Alt + Drag. after release Alt, 3D object will auto jump ..
I am having problems navigating and zooming with Alt + drag
As an example this what happens :
When I press Alt and I click on mouse and drag towards the right, the 3D object will move towards the right.
now the problems is
but when I release the Alt, the 3D object will auto snap back to the original location when before I press the Alt key and also auto zoom out.
This is not how the Alt + Drag is suppose to work.
The correct way for the Alt + Drag to work is :
when I press the Alt + Drag to right, the 3D object should move towards right.
when I release Alt key, the 3D object should stay where it currently is at and as I drag the mouse, the 3D object will zoom in/out
How do I configure Zbrush so that my Alt key works like the second example?
Thank You
I found the solution to this
Zswitcher gives Maya navigation control to Zbrush!!!
Thank you ZSwitcher!!!
