I’m working on a character in Zbrush 2023 and when I click T-Pose Mesh the model breaks, It doesn’t have layers and I also have tried restarting Zbrush, any ideas on what is happening? I’ve used Tranpose master before but I’ve never encontered this issue!
Hi @Sara6
Try “MeshIntegrity” in “Tool > Geometry” to see if there are any problems with the mesh before you use Transpose Master. HTH
Hi, I’ve try it but didn’t find anything wrong with the mesh
, thank you anyway
Hello @Sara6 ,
This may be a problem with the point order in either the TPose mesh or the original subtools no longer matching perfectly. Not only the topology but the point order must remain identical. The Transpose Master documentation describes certain features like the Gizmo Deformers that may alter the point order.
Hello, yeah I know about the gizmo deformers, but that is the mesh when I click to create the tpose mesh, not after posing. I ended finding the subtool that was making the error, delete and redo it, but don’t know yet why it happed. Thank you anyway
