Problem with popup windows
I am trying to use the noisemaker from the popup window, but I can’t use the zoom feature because that section of the window is pushed up above my screen size (other words, I can’t see the top of the noisemaker popup window), and I can’t drag the window down to center it or make it fit to my screen size.
Is there a way to make all popup windows resize to your screen size, or make it so that all popup windows in zbrush will be centered or fit-to-view?
move the button for noisemaker to the top of the screen before you press it.
Are you using a monitor with the minimum resolution Zbrush requires?
You were correct; My monitor size is a wee bit small, so it didn’t show it fully on my screen.
