Problem with Keyshot Content Intaller
I downloaded the Keyshot Content Installer from the email link and tried to install the .dmg file but it gave an error message saying " “ZBrush To KeyShot Content Installer.app” is damaged and can’t be opened. You should eject the disk image." I re-downloaded the file but got the same error message. Is there another way to open or another way to download?
I was able to download and install Keyshot and activate with ZB with no problem. Just don’t have the content…
Never mind - fixed the problem. In case anyone else runs into this - I opened the disc utility and resaved it as a dmg file - opening that file fixed the problem and seemed to install without problem (haven’t looked at the content but I assume it is all ok.)
Had the same problem. Did what was suggested here and the install proceeded.
Thanks for the solution.
Cheers
David
My install apparently worked however I can’t find the content anywhere. Is it suppose to just appear in your keyshot library? Apologies if this is a nube question. First time using Keyshot.
Edit- Sorry I see that’s answered here if anyone else got confused
http://www.zbrushcentral.com/showthread.php?191455-Where-does-the-KeyShot-Content-Installer-install-its-content&p=1124939#post1124939
Thanks Mr.Natural, your solution worked. :+1:small_orange_diamond:+1:small_orange_diamond:+1:
Thank you very much, after two downloads with no fortune with installing, your advice helped. :+1:
Cheers
Philipp
