Problem with Editable Curve in 4R7
Hi… I’m trying to reproduce a task that is easily done in 4r6: Open DefaultSphere.ZPR. Standard brush, set to Stroke>Curve>Curve Mode ON. Set Stroke to DragDot. Draw curve on sphere. Click on curve… result is a stroke of the standard brush that follows the curve. The curve can be moved and the stroke will move with the curve on the surface.
If I try to do this is 4R7, clicking on the curve created with Curve Mode ON does nothing. Actually, it acts like the curve isn’t there and draws a single dot of my stroke right at the click location. If I move the curve, this single dot will follow the cursor and the curve will move with it normally as well, but there is no stroke along the curve.
I hope this is clear enough… It is reproducable after Preferences > Init Zbrush and restarting. I can always do it in 4R6, I cannot for the life of me get it to work in 4R7. I wonder if there is a possibility that I hosed a parameter somewhere buried deep in the UI that I won’t encounter for another year or two and that no one will answer this plea and I’ll never know if it’s a bug, user idiocy or I’m simply losing my mind. Please help.
In case anyone else comes upon this post first, this behavior has been noted elsewhere in the forum, though no resolution is mentioned yet.
Wanted to ask the same question: after 2 days of digging in docs, tons of youtube videos, guts of Z settings i found that the only way to do that is to press alt before you start to draw a curve. After you finish, you can drag it a bit and sometimes it works just fine(and sometimes not).
I don’t know what is the reason of that, since i cannot find any normal documentation to curves in docs at all, whole documentation is a huge mess.
I looked through the PDF too for info on curve stuff, didn’t find what I wanted. :mad: I’d have to agree that a large PDF isn’t nearly as good as what most of us are accustomed to… A ‘real’ Help menu, like what used to be about the standard in any package.
I’m experiencing the same problem in ZB47 with the curve brush functions. ZB46 works as expected.
