Problem with DXF import...
Has anybody had trouble with the import of DXF files? It seems to be hit and miss… :confused:
It works then it doesn’t. Any input anybody? :rolleyes: :rolleyes:
Hey Stonecutter,
I have a 90%success rate with DXF and an 99% success rate with OBJs.
I’m not done trying to figure this out, but I truly believe it has everything to do with the program is came from as well as the size of the mesh.
But then again, I have about the same success rate between my other programs too. So, I don’t necessarily think it’s a problem persay.
I’ve also found that just building them directly in ZBrush gets me where I want to go alot faster.
For some reason (quality?) an imported mesh just doesn’t perform or look as good as an original build in Z. And the odd thing is, I have a 100% success rate in EXPORT to any of my other programs…
I haven’t opened up Anim9or, Blender, Poser, Bryce, Cararra, or Canoma for a while now…
This is my experience and opinion of course. And is worth about .02 on the open market.
:wink: :smiley:
Hi :slight_smile:
Is the problem that you are encountering similar to the problem the was described in this thread?
If you encounter any other difficulties, please email me(if possible) a sample of such file (DXF or OBJ format).
(It could be a result of none-standard file format and ZBrush can most likely be updated to recognize such format.)
-Pixolator
Thanks guys! :slight_smile:
It was a problem importing from Elefont, and the problem, as they say, WAS between the monitor and the back of my chair. I just was closing Elefont before it had finished the triangulation… :smiley: (Should have a smiley here for a ‘What a dummy!’
Thanks for the input, and as usual, it wasn’t ZBrush, but me. When I started using this great software, I thought it had bugs, but it hasn’t given me a problem all week except for this, which was my fault :rolleyes:
I used Elefont for a while, but switched to
Xara3D
and
Amorphium (for the fontman)
BUT there is always more than one way to skin a cat… 8^))
hello zuzu
how is the weather in San Francisco?
:wink:
i am not able to import ANY DXF files from Cinema 4d XL Version 6 into Zbrush.
OBJ works like a charm.
Importing into C4D gives me the headache of having to reverse a few stray normals,
imagine the horror of correcting 20,000 poly model of a face!!
Importing DXF from zbrush into C4D has not given me any problems…
this information is probably more valuable to you then me,
cheers
mason
