Problem with BPR settings
I am pretty new to this software, so I don’t know much about how this works. Here’s a problem I have faced:
I watched a tutorial on how to render a sub tool transparent for making the glasses of the specs I am working on. The video said to go to Display Properties, then BPR Settings. However, when I did so, I had no BPR settings! It only shoes ‘Double’ and ‘Flip’ options. The BPR settings are nowhere to be found. How do I fix this?
Hi @Ayisha
Which version of ZBrush are you using?
Please make sure you’re using an up to date version of the program. The BPR transparency settings are in the Render > Render Properties menu, Render > BPR transparency, and in the Tool > Display Properties BPR Settings (click to expand).
Srry I didn’t mention that! I am using Zbrush Core 2020
Yes I did that.
That’s the prob. There is no BPR Settings there. Only ‘Double’ and ‘Flip’ options.
Hi @Ayisha
ZBrush Core has it’s own dedicated forum. You should post your questions there in the future. You might have better luck with finding the answers you are looking for.
ZBrush Core Support
I’ve actually never used that program so can’t say for certain, but it is listed as only having basic BPR capability.
Yes I will. Thank you for mentioning!
