Problem using zmodeler close convex hole function
Hey everyone,
So when i use zmodeler to delete polys, specifically a circle, and close them back up with the close convex hole, for some reason i cant get any elevation (curvature). I know im supposed to be able to drag in a different direction to get elevation, i’ve even done it before, but for some reason its suddenly not allowing me to. I’m sure theres some setting i adjusted that did something but I have absolutely no clue what it is. Help would be appreciated.
Thanks
This is a known issue and the developers are aware of it. It should be fixed in the next patch release.
Whew, glad it wasn’t just me. Thank you!
also, does anyone know if i need to download that patch and install manually or does the program patch itself?
You should get instructions when the patch is released.
