problem projection master on mac
hi,when i am in projection master i create a 3d plane with a texture to map my object pmd.But one time i succeed obtain the alpha,and sometimes not.Is it a bug?
i put zadd off z intensity 0…thanks for help.
I’m sorry, but I’m not quite sure what you mean.
in fact,i don’t want white background :just the flower which is on a transparent background in photoshop.I have put z intensity to zero but i have always this background.What can i do?;Is Z project better for doing that,and how to proceed?
Thanks a lot.
Your texture needs to have a pure black background. (0,0,0) Then turn on the Texture>Transparent option.
Or you can create a separate alpha and load that into the Alpha palette. The places that you don’t want to be visible should be black. Be sure to set Z Intensity to 0.
thanks i have tried and it’s ok.In fact i had not thought to initialize enough my plane 3d. But in the french dvd of zbrush, the exercise is showed with a white
background…
hi ,i had cried too soon victory:today i try another thing and this time even my plane 3d is fully initialize, when i pick projection master nothing appears…with zbrush, it is one day yes and one day not.Desesperate.
Before dropping the model, did you fill it with color? With white selected and Draw>Rgb on press Color>Fill Object. Then use PM to drop the model.
Surfeur: I invite you posting at www.ZBrush.fr forum. Alexis, the CD training creator will answer you for your training problem.
In french:
Hello Surfeur ! Le mieux est de poster ton message sur le forum de www.ZBrush.fr. Alexis, l’auteur du CD qui est un des cofondateur du site répondra à tes questions, surtout celle relative à sa formation :slight_smile:
hi, yes i have filled object with flat color and a grey color.Is white color an
obligation?Thanks.
