Hi Aurick - thanks for the reply.
There are two error messages, the first is:
“unable to read the specified file”
This one seems to occur when trying to import the .bmp and .tif version of the file.
The second is:
“error encountered while loading a file”
I got this message when trying the .psd version. All versions were based on the .bmp and .tif saved out of Zbrush and then saved again from Pshop. Photoshop and Bodypaint are able to load all the various versions without any trouble so there isn’t anything wrong with the files that I can see.
Here’s a twist though: I have since tested it on another machine and that one will load the .jpg and the .psd, but not the .tif or .bmp. Install is exactly the same on both. First machine is a dual dual-core Opteron running xp64 pro, 6GB of available RAM. The second machine is a dual-quad core Xeon with 8GB of RAM, also running xp64 pro. The install is the same on both, using 3.1 update and the only add-on is Zapplink - which is installed on both.
I can uninstall and re-install again, but it seem likely that there is something else amiss given that it occurs on two machines slightly differently.
Thanks for any help.
b
