It´s very simple (or not) ¿Can anyone made a script to put the presure in two hotkeys? For tab up and down (size, intensity and else) while sculpting, whitout release the mause. Tell me is not a good implement.
tanks since…now
This sounds horrible
Think about that, maybe not with a key, perhaps with the mause wheel. So no need to interrupt the workflow.
Also no need to be a closed mind, many of us dont have the resources at first.
You couldn’t script this because the adjustment would always interrupt the mouse movement. Anyway what you want is already provided in ZBrush if you use a graphics tablet (like those made by Wacom). I think you’ll find that most artists who use ZBrush a lot use a tablet.
yeah, a draw tablet makes a world of difference and it doesn’t really need to be a really expensive one, as long as you have a decent amount of pressure levels, it’ll be fine.
I´m aware of tablets, my idea was to simulate them with a recontructed mause in form of a pen that i have. I hope you understand my obsession and sorry if i´m a little…insistent. Tanks.
You just gave me a splendid idea.
I am an electronics tinker and I an construct a device that will connect to a pen and give you a tablet like pressure. Perhaps I can adapt it to ZB for a simulation of the tablet. Will not be as good but worth a test and would be a good project to get my fingers wet with ZB code/scripting
I am glad that someone shares the vision.
Good luck in your quest!!
Thanks.
I consider it a challenge.
It will take some time to develop this.
I have to work on parts selection and not to mention learn how to write code to hook into ZB and the OS to allow it to work.
