i have recently had a major computor disaster
had to buy new comp and reload every thing problem is when i press on a body part i dont get the attribute bar for morphing
everything is working really well aside from this it just has me stumped help would be apreciated
thanks paton:rolleyes:
Not quite sure what you mean. Can you describe your problem in a different way and maybe include a screenshot?
when i have my poser figure displayed in the picture
and for example i double clik on his head, the atribute tool box should apear with
head morphs scale ect…
but it dosnt apear
wondering if there is something simple im missing
ideas welcome
I don’t have it in front of me but in the top tool/menu bar I think there is a menu called window or something similar…you should be able find and load the attribute thing that way.
I’ll double check if I get a chance later but til then …look thru the menus on the top tool line.
In Poser 5 you don’t need to double click. Just click once, and you get a two paned window with tabs Parameters and Properties. In the Properties panel is a button ‘Add Morph Target’. That’s the one you want.
Or, as Aminuts was struggling to remember (:lol: ), in the Tool bar click Object > Load Morph Target. Does the same thing.
Oh yeh … if stuff goes missing, just select factory defaults in Preferences.
ok Moochie,
folks who have friends as old as Horace…should have more compassion for their elders my friend:rolleyes: .
i have tried the programs factory settings
and I did as you sujested with the morph
all pannels apear and everything working perfectly apart from the atribute pannel:rolleyes:
a single click on limbs still dosnt bring anything up
thanks for your sujestions Im very grate full
if any 1 has any other ideas would apreciate enormously:lol:
Have you tried the ever horrid…reinstall?
If it isn’t available that might be your best bet at this point. I cannot say for sure because I don’t know at this point what os was originally on your computer and what they did to “fix” it.
if the reinstall doesn’t work…go to curious labs and to your video card maker and to windows sites and do searches specific to your problem in the first place…something will come up cuz you can’t be the only one in the universe with the problem…someone somewhere had a similar problem and got an answer that will help you!!!
i will try and do some more research thanks for trying:D
What were you expecting this ‘attribute panel’ to show you? I’m wondering if you’re in the wrong ‘room’ in Poser. Perhaps you want material settings or something.
the atribute bar im talking about is the 1 if you click on the face you can
morph into different heads eg make nose bigger ect
and if you click on circle surounding body you can make figure bigger smaller ect:lol:
Try hitting Ctrl+Shift+N (if you’re on a pc). Not sure what the Mac equivalent is.Also check out all the options in the Windows menu in the top tool bar. I think you’ve unclicked something.If no good, try over at Renderosity or contact Curious Labs. Good luck.
Try Ctrl+Shift+N. And check out all the options in the Windows menu in the top tool bar. I think you just unchecked something. Good luck.
Try Ctrl+Shift+N.
Try Ctrl+Shift+N. And check the options in the Window menu in the top tool bar. I think you’ve just unchecked something.
Hooray … I think the site code is throwing a wobbler.
all the other combinations in the windows area work with their
shift ctrl combinations making variouse tools apear and disapear
I have also tried going around the edges of poser to see if the
paramaters is on the edge and just needing to be draged in
kind of crazy because everything else is working so well
I do apreciate all your ideas:lol:
im sure its something simple {I hope}
Ihave also contacted curious labs a few times but it may still be the weekend for them
thanks again for all your sujestions:lol:
Have you tried launching back to the original factory setting?
Menu bar/Edit/General Preferences/ Launch to factory sate.
thanks for trying
appreciate all sujestions
curiouse labs in contact now so far sujestions similar to you guys
no answer yet
thanks guys:lol:
