Hi emdee,
This black silhouette is the classic result when you try to apply polypaint to a texture map from a polymesh that doesn’t have proper UV mapping.
Try this with your polypainted model in edit mode:
Under TOOL:Texture, click on AUV. (you will have to set TOOL:Geometry:SDiv slider to 1, first). ZBrush will apply UV mapping to your model.
Now, be sure your texture map is selected and simply click the PolyPainting buttons in this order:
Click SaveUV button - when it asks if you “Initialize PolyMesh with Texture Map colors?” ANSWER NO…
Click HideMap button and you should see your polypainting on the polymesh. If you didn’t save your model with the polypainting intact, apply new polypainting until you are satisfied…
Click ShowMap button and you should see the original texture map reloaded.
Click PolyPaint to TexMap button and your polypainting will be transferred to the texture map.
Sven
