Polypainting from image gets blurry if done for a distance
Hello!
I’m trying to polypaint a model using Spotlight and a reference image.
When I zoom really closely, I get the details of the reference image transferred to my model.
This is great.
However, when I try to polypaint from a distance, the polypaint gets blurry.
In the screenshot, you can see that the hairs painted from a distance are much less crisp than the hairs painted when I zoomed in VERY closely.
Is there any setting that I could activate to paint sharp / crisp even from a distance?
If you mean Spotlight (which it looks like based on that image), then AFAIK it is designed to basically punch right through your screen to transfer the color information from Spotlight’s visible pixels (and only those pixels) onto the model. In other words Spotlight is not using the image’s raw information all by itself, but is instead looking at what you can actually see of that image on your monitor’s pixels (or perhaps the document’s pixols) and it projects that information.
Example: If you have a massive 8K image loaded into Spotlight but sized so that you can fit the entire thing on the screen, then you’re not going to be projecting 8k worth of pixel details because all those image’s pixels are not actually visible on your screen. The image is being downsized by spotlight to fit on your screen, and what you see is what you’ll get from the projection.
In a sense, the model scale works the same way. Even if the model has a perfect density of vertices to support all the required detail, if it is scaled in a way that one pixel from the Spotlight image covers half of the points on the model then all those points are going to wind up having the same color information projected onto them.
So ideally you would want to aim for a 1:1 ratio between the two for a pixel-perfect projection. There’s no shortcut where you can zoom out and paint an entire high res character in one stroke. If you’re doing a full character then you’ll probably want to start from a distance to lay down a blurred overall sense of the coloring, and then move in closer with each pass to get the finer / sharper details (sort of like sculpting and painting in general where you do the large forms first before focusing on the smaller details).
Thank you for the information.
The thing is that I have full body textures, and I was hoping I could transfer most of it in “one stroke” as you said.
Well, now at least I know that I have to think differently.
Your explanation was great.
So that’s the way you do it, too?
Or do you additionally use any other software for texturing?
