Polypainting and overwriting a texture
I am having an issue in which I am trying to continue a poly painting which I have already converted to a texture map. I can continue to paint just fine, but for some reason I am not able to overwrite the original texture map when I push the “New from Polypaint” button. All it does when I push the “New from Polypaint” button is turn on the original texture. Below is the procedure as listed on Pixologics website, but it does not seem to work as described. Thoughts?
“If you wish to continue PolyPainting simply press Tool > Texture: Map > Texture Off and continue painting. When you want to convert your new painting onto a texture map simply repeat step 2 above. You can use the same texture. It will simply overwrite the information that was there before.”
Thanks for the assistance.
Just turning off “Texture On” button in “Tool > Texture Map” won’t do it. You have to click on the texture selection icon in “Tool > Texture Map” and select “Texture Off” from the flyout.
