Polypaint Symmetry Stronger on one half
Hi.
I’m polypainting a model with symmetry on and noticing that the paint job is stronger on one half of the model then the other. Unifying the model does not fix the problem, as it doesn’t seem to be an offset issue, only the pressure of application. Is there a reason or a setting that would alter the strength of painting with symmetry one half of the model?
Thank-you
edit:
It looks like it could be a subtle symmetrical offset. Smart resym clocks up to 96 percent, but perhaps due to the subtle slide in body volume the pressure application is stronger on one half. Curious as to how to fix this or how it happened.
Go to subdivision level 1 and hit ReSym, then hit Smart Resym. Now work your way up each subdivision level and hit Smart Resym until you reach your highest subdivision level.
Thank-you.
